Introduction
If the coffee runs out of the coffee machine poorly or on one side, the coffee spout is often soiled with coffee fat. This shows how it can be opened and cleaned or replaced.
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggia—they are all made by the same manufacturer and have a very similar design.
Ce dont vous avez besoin
First check which model you have in front of you: is the decorative frame made of chrome-plated metal (picture 1) or made of metallized plastic (picture 2). In the first case use this guide, in the second case use this guide. Then come back here.
The control panel is locked at the bottom. Very carefully pull the labeled plate of the control panel upwards and put it to one side.
The electrical part of the control panel is still attached to the left and right at the bottom with two Torx T10 screws. Loosen this and carefully remove the control panel.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
