Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement
    1. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement, The motherboard: étape 1, image 1 de 1
      • Before you begin, switch off your phone.
      • Heat your phone to about 195 degrees Fahrenheit (90 C).
      Demander à FixBot
      Ajouter un commentaire
    2. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 2, image 1 de 1
      • Lift the back cover to create a gap between the glass and the frame.
      • Insert an opening pick into the gap.
      Demander à FixBot
    3. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 3, image 1 de 1
      • Start sliding the opening pick from the lower left corner along the side of the device to cut the adhesive
      • Leave the opening pick in the side to prevent the adhesive from resealing.
      Demander à FixBot
    4. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 4, image 1 de 1
      • Lift the cover open like a book, but be careful to make sure you do not damage the flex cable while it’s still connected.
      Demander à FixBot
    5. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 5, image 1 de 2 Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 5, image 2 de 2
      • Using a screwdriver (1.5 mm ), unscrew 4 screw and remove the bracket holding the connector.
      Demander à FixBot
    6. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 6, image 1 de 1
      • Disconnect the connector to avoid a possible short circuit during disassembly.
      • Disconnect connectors and remove the inter-board cable.
      Demander à FixBot
    7. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 7, image 1 de 3 Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 7, image 2 de 3 Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 7, image 3 de 3
      • Using a screwdriver (1.5 mm), unscrew the 7 screws.
      • Remove the cover.
      Demander à FixBot
    8. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 8, image 1 de 1
      • Pry up on the connector and remove the fingerprint sensor cable.
      Demander à FixBot
    9. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 9, image 1 de 1
      • Disconnect the connector on PCB, and remove the front facing (selfie) camera.
      Demander à FixBot
    10. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 10, image 1 de 1
      • Disconnect the connectors on the PCB.
      Demander à FixBot
    11. Replacement of the motherboard of Xiaomi Redmi Note 7 Pro Motherboard Replacement: étape 11, image 1 de 1
      • Pull off and remove the PCB.
      Demander à FixBot
26 autres ont terminé cette réparation.
Merci à ces traducteurs :
es en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Remphone.ru
Membre depuis le 10/02/19
846 Réputation
1 tutoriel rédigé
1 commentaire de tutoriel
Give Me Your Phone Number..
The Comedy King - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 53
30 derniers jours : 186
Total : 15,147
