Aller au contenu principal
Replacing Antenna on Realistic Weatheradio
Ce dont vous avez besoin
  1. Replacing Antenna on Realistic Weatheradio, Antenna: étape 1, image 1 de 1
    • To remove the back panel from the Weather radio, use your index finger and push down on the tab located on the back.
  2. Replacing Antenna on Realistic Weatheradio: étape 2, image 1 de 1
    • Use a Phillips 1X80 screwdriver to loosen the screw located on the bottom right of the back panel.
    • Do not attempt to remove the screw because it will not come out.
  3. Replacing Antenna on Realistic Weatheradio: étape 3, image 1 de 2 Replacing Antenna on Realistic Weatheradio: étape 3, image 2 de 2
    • Once the screw is loose, slowly pull out the antenna until it is completely out.
    • Once the antenna is out, you can replace it with the new one.
    • Do not force the antenna inside and make sure it is coiled all the way down.
After following these steps, the Realistic Weatheradio should be able to work and function normally.
2 autres ont terminé cette réparation.
Pièces jointes
Matthew
Membre depuis le 07/17/15
136 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team 3-5, Rauch SU 2015 Membre de l'équipe Texas Tech, Team 3-5, Rauch SU 2015
TTU-RAUCH-SU15S3G5
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 19
Total : 929
