Aller au contenu principal
Replacing Creative Zen X-Fi Speaker
Ce dont vous avez besoin
  1. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: étape 1, image 1 de 3 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: étape 1, image 2 de 3 Replacing Creative Zen X-Fi Speaker, Detaching Front Case: étape 1, image 3 de 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Speaker, Rubber Button Cover: étape 2, image 1 de 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Speaker, Button Input Chip Part 1: étape 3, image 1 de 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Speaker, Button Input Chip: étape 4, image 1 de 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Speaker, Access Midsection Plate: étape 5, image 1 de 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Speaker, Unscrew below Button Chip: étape 6, image 1 de 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Speaker, Unscrew below LCD Screen: étape 7, image 1 de 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: étape 8, image 1 de 2 Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: étape 8, image 2 de 2
    • Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
    • Once unscrewed, pick up the case and put it to the side.
  9. Replacing Creative Zen X-Fi Speaker, Removing the Speaker: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
Westley Courchene
Membre depuis le 01/13/15
3 389 Réputation
14 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Remmell Fall 2015 Membre de l'équipe USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 326
