Aller au contenu principal
Replacing Motorola V60i Logic Board
Ce dont vous avez besoin
  1. Replacing Motorola V60i Logic Board, Battery: étape 1, image 1 de 2 Replacing Motorola V60i Logic Board, Battery: étape 1, image 2 de 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Replacing Motorola V60i Logic Board: étape 2, image 1 de 2 Replacing Motorola V60i Logic Board: étape 2, image 2 de 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Replacing Motorola V60i Logic Board, Back Plate: étape 3, image 1 de 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Replacing Motorola V60i Logic Board: étape 4, image 1 de 2 Replacing Motorola V60i Logic Board: étape 4, image 2 de 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Replacing Motorola V60i Logic Board: étape 5, image 1 de 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Replacing Motorola V60i Logic Board, Motherboard: étape 6, image 1 de 1
    • Gently lift logic board from back plate.
  7. Replacing Motorola V60i Logic Board: étape 7, image 1 de 2 Replacing Motorola V60i Logic Board: étape 7, image 2 de 2
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
Elizabeth OBrien
Membre depuis le 04/26/10
43 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 30-40, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 membres
14 tutoriels rédigés
Un commentaire
Quero comprar esse aparelho, alguém tem para vender?
Karison Mesquita - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 16
Total : 2,183
