Aller au contenu principal
  1. Before disassembling your phone, be sure it is powered off. To remove the back cover press the two "buttons". Remove the battery.
    • Before disassembling your phone, be sure it is powered off.
    • To remove the back cover press the two "buttons".
    • Remove the battery.
  2. Remove the three 3mm black screws on the top of the phone. Remove the two 5mm screws.
    • Remove the three 3mm black screws on the top of the phone.
    • Remove the two 5mm screws.
    • Loosen these two screws at the bottom of the phone.
    • Probably these screws will not come out from their home, no matter. It is only important to unscrew them completely.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. With a plastic opening tool remove the little piece of plastic in the bottom of of the phone. The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them. To remove the logic board assembly push from the rear of the phone.
    • With a plastic opening tool remove the little piece of plastic in the bottom of of the phone.
    • The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them.
    • To remove the logic board assembly push from the rear of the phone.
  5. Remove the keyboard with a plastic opening tool. Remove the keyboard with a plastic opening tool.
    • Remove the keyboard with a plastic opening tool.
11 autre(s) ont terminé cette réparation.
Matteo Moro
Membre depuis le 21/02/2013
476 Réputation
1 tutoriel rédigé
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 4,277
