Aller au contenu principal
Replacing The PODZ Port
Ce dont vous avez besoin
  1. Replacing The PODZ Port, Rear Cover PODZ Port: étape 1, image 1 de 3 Replacing The PODZ Port, Rear Cover PODZ Port: étape 1, image 2 de 3 Replacing The PODZ Port, Rear Cover PODZ Port: étape 1, image 3 de 3
    • Remove the 6 screws securing the lens cover bezel using a #00 Phillips screwdriver. This will allow you to remove the bezel and lens cover.
  2. Replacing The PODZ Port: étape 2, image 1 de 1
    • Remove the metal camera body cover by sliding it toward the lens end of the camera.
  3. Replacing The PODZ Port: étape 3, image 1 de 1
    • Remove 2 screws on the bottom of the camera body using a #00 Phillips screwdriver.
  4. Replacing The PODZ Port: étape 4, image 1 de 1
    • Remove the 3 screws that secure the camera to the body using a #00 Phillips screwdriver.
  5. Replacing The PODZ Port: étape 5, image 1 de 1
    • Use a plastic pry tool to remove the plastic ring covering the rear screws.
  6. Replacing The PODZ Port: étape 6, image 1 de 2 Replacing The PODZ Port: étape 6, image 2 de 2
    • Remove the 8 screws around the perimeter of the back cover.
    • Remove the 2 screws in the PODZ port.
  7. Replacing The PODZ Port: étape 7, image 1 de 1
    • Slide PODZ port out of the camera body.
    • Disconnect ribbon cable from the back of the PODZ port.
    Either de-solder de microphone black and red wires or cut them midway to rejoin again later to remove the camera from within the housing
    Fernando d'Hyver - Réponse
Christopher Brandl
Membre depuis le 10/09/18
673 Réputation
5 tutoriels rédigés
Équipe
UW Stout, Team S6-G2, Ogden Fall 2018 Membre de l'équipe UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 membres
5 tutoriels rédigés
Un commentaire
How do you reconnect the ribbon cable to the back of the PODZ port when you reassemble?
Peter Niepel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 11
Total : 580
