Introduction
Breaking the invisible zipper of your fancy cocktail dress or everyday skirt doesn't need to be a tragic affair anymore. Following this guide will let you easily replace an invisible zipper and bring new life to the outfit gathering dust in the back of your closet. You will need a sewing machine and basic knowledge of how to operate it for this guide.
Ce dont vous avez besoin
Thread the needle thread through the invisible zipper foot hole.
Pull the needle thread through the zipper foot hole.
Locate the stitch lines of where the broken zipper was sewn on both sides of your garment.
Use a seam ripper to carefully rip out both of the stitching lines.
Remove old invisible zipper.
Turn the skirt right-side out again, so you don't see the zipper teeth.
Rotate the fabric so the zipper foot is perpendicular to the zipper tape.
Position the zipper foot on top of the fabric 1/8th of an inch from where the zipper tape meets the garment.
Sew back and forth at least 6 times to seal the end.
Flip garment over to see the stitch line you just made. Cut off excess zipper tape.
