Aller au contenu principal
ResMed VPAP Auto 25 Circuit Board Replacement
Ce dont vous avez besoin
  1. ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: étape 1, image 1 de 3 ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: étape 1, image 2 de 3 ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: étape 1, image 3 de 3
    • Remove the four 26.7 mm T3 Torx screws from the bottom side of the ResMed VPAP Auto 25.
  2. ResMed VPAP Auto 25 Circuit Board Replacement: étape 2, image 1 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 2, image 2 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 2, image 3 de 3
    • Flip the device over.
    • Pry the outermost plastic cover off with the metal spudger until the cover is loose and able to be removed.
  3. ResMed VPAP Auto 25 Circuit Board Replacement: étape 3, image 1 de 2 ResMed VPAP Auto 25 Circuit Board Replacement: étape 3, image 2 de 2
    • Pull off the front cover to reveal the internal components.
  4. ResMed VPAP Auto 25 Circuit Board Replacement: étape 4, image 1 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 4, image 2 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 4, image 3 de 3
    • Loosen the motherboard from the rubber dowels holding it in place and unplug the screen components.
  5. ResMed VPAP Auto 25 Circuit Board Replacement: étape 5, image 1 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 5, image 2 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 5, image 3 de 3
    • Remove the three 26.7 mm T3 Torx screws from the now visible rubber fan motor cover.
    • Lift off the rubber fan motor cover, revealing the fan motor.
  6. ResMed VPAP Auto 25 Circuit Board Replacement: étape 6, image 1 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 6, image 2 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 6, image 3 de 3
    • Remove the fan motor unit from its housing.
    • Remove the three 26.7 mm screws securing the motor housing to the bottom piece with a T3 Torx screwdriver.
  7. ResMed VPAP Auto 25 Circuit Board Replacement: étape 7, image 1 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 7, image 2 de 3 ResMed VPAP Auto 25 Circuit Board Replacement: étape 7, image 3 de 3
    • Pull out the fan motor housing from the bottom cover, revealing a foam insulation pad and the circuit board.
    • Slide the circuit board out of its plastic grooves in the bottom cover to retrieve the desired component.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 230
