Aller au contenu principal
Resetting the Palm m105
Ce dont vous avez besoin
  1. Resetting the Palm m105, Device Reset: étape 1, image 1 de 1
    • To soft reset the device, use a paperclip to carefully press the reset button located on the back of the device. The exact location of the button can be seen in the picture.
    • A soft reset means that it will usually not affect your personal data on your device, unless the batteries are low.
    • After you press the button, the device will reboot as if you just powered on your device and it should clear up most common device problems.
    • If your device is still not powering up or has a blank display, the next step will help you perform a hard reset of the device.
  2. Resetting the Palm m105: étape 2, image 1 de 2 Resetting the Palm m105: étape 2, image 2 de 2
    • A hard reset will erase all current data on the device. This should only be done if a soft reset has not solved your problem.
    • A hard reset is done by simultaneously holding down the power button while also pressing the reset button on the back with a paper clip like you did for the soft reset. After a few seconds the Palm logo should appear, when it does, release the power button.
    • If applicable, you can restore any data previously synchronized with your PC through the HotSync operation of the device.
Erik Thompson
Membre depuis le 10/04/11
31 Réputation
5 tutoriels rédigés
Équipe
UW Stout, Team 1-3, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 15
Total : 1,379
