Aller au contenu principal
Retrait de vis à tête fraisée Allen cassée
Ce dont vous avez besoin
  1. Retrait de vis à tête fraisée Allen cassée, Retrait de vis à tête fraisée Allen cassée: étape 1, image 1 de 1
    • Taillez une fente dans la tête de la vis.
    • Placez le tournevis dans la fente et tapez avec un marteau dans le sens inverse des aiguilles d'une montre afin de desserrer le boulon.
    • Dévissez le boulon avec le tournevis.
Ligne d'arrivée
44 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Wolfgang
Membre depuis le 02/17/12
597 Réputation
2 tutoriels rédigés
6 commentaires
Use the same technique for Philips or crosshead screws.
Use a grinding / cutting disk, not a saw blade. Apply the rotating cutting disk gently, do not force or it will break.
If this is a toughened steel or stainless steel bolt (much tougher), it will be best to use a reinforced cutting disk.
Use a dusk mask to avoid breathing the dusk from the disk !
(No, I don't usually, but I should !)
Frank B - Réponse
While this works it is very difficult to not ruin the material around the bolt.
What I do is use a torx bit. size one up that is slightly larger then the hole and then firmly tap it in. atttach your drive handle a turn slowly while pushing down. this will normally break it free.
Also before your get to this point try putting your allen key in the hole and smack it with a hammer. sometimes the force of the hit will cause the metal to "break" enough that the allen screw wont strip.
Jamie Mcguire -
There are also specifically designed screw extractors made for this. These tools are generally two-sided: one side is used to drill the hole, while the other is inserted to extract. If the process works, the surrounding area is undamaged.
Karl Kaufmann - Réponse
Use another Allen bolt to weld over it and then you can easily remove the Allen bolt with the help of Allen key
Tushar Pednekar - Réponse
And if for any reason if you can't weld then just drill the head of the Allen bolt so it's shears off. And then u can easily remove the rest
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 104
30 derniers jours : 465
Total : 258,341
