Aller au contenu principal
Revlon 473 Hair Dryer Switch Replacement
Ce dont vous avez besoin
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: étape 1, image 1 de 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: étape 2, image 1 de 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: étape 3, image 1 de 3 Revlon 473 Hair Dryer Switch Replacement: étape 3, image 2 de 3 Revlon 473 Hair Dryer Switch Replacement: étape 3, image 3 de 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: étape 4, image 1 de 1
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: étape 5, image 1 de 1
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: étape 6, image 1 de 1
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
Jessica Leyva
Membre depuis le 09/18/12
143 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-5, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 33
Total : 1,821
