Aller au contenu principal
Revlon 473 Thermal Cutout Replacement
Ce dont vous avez besoin
  1. Revlon 473 Thermal Cutout Replacement, Shell: étape 1, image 1 de 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Thermal Cutout Replacement: étape 2, image 1 de 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Thermal Cutout Replacement: étape 3, image 1 de 3 Revlon 473 Thermal Cutout Replacement: étape 3, image 2 de 3 Revlon 473 Thermal Cutout Replacement: étape 3, image 3 de 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Thermal Cutout Replacement, Thermal Cutout: étape 4, image 1 de 1
    • Locate the thermal cutout under the coils of the heating element.
  5. Revlon 473 Thermal Cutout Replacement: étape 5, image 1 de 1
    • Test the thermal cutout for continuity using the multimeter.
    • Make sure the multimeter is set to 200 ACV and bring the probes toward the thermal cutout.
    • If the numbers on the multimeter continue to change, the circuit is closed and properly functioning.
    • If the multimeter reads a consistent number, the circuit is opened and the thermal cutout needs to be replaced.
  6. Revlon 473 Thermal Cutout Replacement: étape 6, image 1 de 1
    • To replace the thermal cutout, use the spudgers to extract the object.
    • To remove, wedge it back and forth until it comes free.
    • You do not need to take out the gold piece, only the thermal cutout.
  7. Revlon 473 Thermal Cutout Replacement: étape 7, image 1 de 1
    • Replace the old thermal cutout with a new thermal cutout by snapping it into place.
Jessica Leyva
Membre depuis le 09/18/12
143 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-5, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 10
Total : 1,866
