Introduction
If your Revlon One-Step Hair Dryer will not power on after multiple troubleshooting attempts, the plug may be defective. As a result, this guide will teach users how to properly replace the cord and plug.
Ce dont vous avez besoin
First, remove the pink panels on each side of the handle in order to access the screws.
Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
Next with your free hand carefully pull the cord out of the port of the dryer handle.
2 autres ont terminé cette réparation.
