Aller au contenu principal
Revlon RVDR5061 Heating Element Assembly Replacement
Ce dont vous avez besoin
  1. Revlon RVDR5061 Heating Element Assembly Replacement, Fan/Motor Assembly: étape 1, image 1 de 1
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Heating Element Assembly Replacement: étape 2, image 1 de 1
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Heating Element Assembly Replacement: étape 3, image 1 de 1
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Heating Element Assembly Replacement: étape 4, image 1 de 3 Revlon RVDR5061 Heating Element Assembly Replacement: étape 4, image 2 de 3 Revlon RVDR5061 Heating Element Assembly Replacement: étape 4, image 3 de 3
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
  5. Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: étape 5, image 1 de 2 Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: étape 5, image 2 de 2
    • Once the fan/motor assembly is disconnected from the heating element assembly you will see that the heating element assembly is connected to a circuit board by four wires. The color of these wires are grey, black, purple and brown.
  6. Revlon RVDR5061 Heating Element Assembly Replacement: étape 6, image 1 de 3 Revlon RVDR5061 Heating Element Assembly Replacement: étape 6, image 2 de 3 Revlon RVDR5061 Heating Element Assembly Replacement: étape 6, image 3 de 3
    • Desolder these four wires one by one from the circuit board.
  7. Revlon RVDR5061 Heating Element Assembly Replacement: étape 7, image 1 de 1
    • The heating element assembly will now be separated from the circuit board and can be replaced with a new one.
Soneil Pitamber
Membre depuis le 07/11/18
97 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G2, Wilson Summer 2018 Membre de l'équipe IUPUI, Team S2-G2, Wilson Summer 2018
IUPUI-WILSON-SU18S2G2
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 788
