Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Revlon RVIR1008 Barrel Shell Replacement
Ce dont vous avez besoin
  1. Revlon RVIR1008 Barrel Shell Replacement, Barrel Shell: étape 1, image 1 de 1
    • Place curling iron on a flat surface along with required tools and barrel shell replacement.
    • Curling iron is extremely hot after use. Carefully unplug and let device sit and cool to room temperature before proceeding.
  2. Revlon RVIR1008 Barrel Shell Replacement: étape 2, image 1 de 1
    • Using both hands, carefully detach both ends of the metal stand from the body of the iron by pulling away from the barrel.
  3. Revlon RVIR1008 Barrel Shell Replacement: étape 3, image 1 de 2 Revlon RVIR1008 Barrel Shell Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Unscrew the 3mm screws from both sides of the barrel clip with a 3.0 flathead screwdriver to remove the clip from the barrel.
    • Set the two screws and barrel clip aside for reassembly.
    • Clip is prone to pop off from the body due to the weight of the spring. To prevent this, equally loosen each screw little by little.
  4. Revlon RVIR1008 Barrel Shell Replacement: étape 4, image 1 de 2 Revlon RVIR1008 Barrel Shell Replacement: étape 4, image 2 de 2
    • Squeeze both sides of the barrel clip spring and slide the component away from the barrel to remove.
    • Slowly decompress the spring after removal from the spring plate to avoid any hazards.
  5. Revlon RVIR1008 Barrel Shell Replacement: étape 5, image 1 de 2 Revlon RVIR1008 Barrel Shell Replacement: étape 5, image 2 de 2
    • Remove 3mm screw holding the metal spring plate in place with the 3.0 flathead screwdriver.
    • Place the screw and plate to the side for later reassembly.
    • Removing the screw allows for removal of the barrel from the iron itself. Be sure not to pull the barrel.
  6. Revlon RVIR1008 Barrel Shell Replacement: étape 6, image 1 de 3 Revlon RVIR1008 Barrel Shell Replacement: étape 6, image 2 de 3 Revlon RVIR1008 Barrel Shell Replacement: étape 6, image 3 de 3
    • Remove the two screws holding the plastic casing together using the 3.0 flathead screwdriver.
    • Remove the front plastic cover from the main body.
    • The plastic cover contains warnings and is located on the devices handle.
    • Once completed, the internal parts of the iron will be exposed.
    • Place the two screws and plastic cover to the side for later reassembly.
  7. Revlon RVIR1008 Barrel Shell Replacement: étape 7, image 1 de 1
    • Remove the cylindrical barrel shell by sliding it away from the devices main heating element. wisdom here.
    • Retrieve replacement barrel shell and slide it onto the devices main heating element.
    • Be careful to grip the device firmly and precisely to avoid stripping away the internal components underneath the handle.
Cassidy Madrigal
Membre depuis le 04/10/17
113 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team S3-G2, Liner Spring 2017 Membre de l'équipe UW Tacoma, Team S3-G2, Liner Spring 2017
UWT-LINER-S17S3G2
3 membres
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 11
Total : 320
