Aller au contenu principal
Rexing V1P Plus Battery Replacement
Ce dont vous avez besoin
  1. Rexing V1P Plus Battery Replacement, Battery: étape 1, image 1 de 3 Rexing V1P Plus Battery Replacement, Battery: étape 1, image 2 de 3 Rexing V1P Plus Battery Replacement, Battery: étape 1, image 3 de 3
    • Orient the device with the LCD screen facing down.
    • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
  2. Rexing V1P Plus Battery Replacement: étape 2, image 1 de 3 Rexing V1P Plus Battery Replacement: étape 2, image 2 de 3 Rexing V1P Plus Battery Replacement: étape 2, image 3 de 3
    • Remove the back cover of the device and place it to the side, with care not to strain the connected battery cable.
    • Rotate the device 180 degrees to where the camera is facing you.
  3. Rexing V1P Plus Battery Replacement: étape 3, image 1 de 3 Rexing V1P Plus Battery Replacement: étape 3, image 2 de 3 Rexing V1P Plus Battery Replacement: étape 3, image 3 de 3
    • Remove the two 5 mm screws on either side of the lens using the Phillips #00 screwdriver.
  4. Rexing V1P Plus Battery Replacement: étape 4, image 1 de 3 Rexing V1P Plus Battery Replacement: étape 4, image 2 de 3 Rexing V1P Plus Battery Replacement: étape 4, image 3 de 3
    • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
  5. Rexing V1P Plus Battery Replacement: étape 5, image 1 de 3 Rexing V1P Plus Battery Replacement: étape 5, image 2 de 3 Rexing V1P Plus Battery Replacement: étape 5, image 3 de 3
    • Remove the two 5 mm screws securing the camera support bracket using the Phillips #00 screwdriver.
  6. Rexing V1P Plus Battery Replacement: étape 6, image 1 de 3 Rexing V1P Plus Battery Replacement: étape 6, image 2 de 3 Rexing V1P Plus Battery Replacement: étape 6, image 3 de 3
    • Carefully remove the plastic frame from its previously secured position on the motherboard.
    • It will rest loosely around the white camera ribbon.
    • Rotate the device 180 degrees to where the camera is facing away from you.
  7. Rexing V1P Plus Battery Replacement: étape 7, image 1 de 3 Rexing V1P Plus Battery Replacement: étape 7, image 2 de 3 Rexing V1P Plus Battery Replacement: étape 7, image 3 de 3
    • Using a soldering iron, remove the two wires connecting the battery to the motherboard.
    • Soldering has the potential to burn you or damage your device. Check out this guide before beginning, take appropriate precautions, and always solder in a well-ventilated area.
    • Once the wires are removed, peel the battery off of the case adhesive.
Caleb Slentz
Membre depuis le 02/14/23
256 Réputation
2 tutoriels rédigés
Équipe
2 commentaires
Where is it possible to get the replacement battery? Searching on ebay reveals nothing for the information given.
Derek Piper - Réponse
Just realized this appears to be what is known as a 'super capacitor' rather than a battery so it's possible any 5.5V 3.5Farad capacitor will work. The form factor may be an issue though.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 92
Total : 1,223
