Aller au contenu principal
Rexing V1P Plus Screen Replacement
Ce dont vous avez besoin
  1. Rexing V1P Plus Screen Replacement, Front Camera: étape 1, image 1 de 3 Rexing V1P Plus Screen Replacement, Front Camera: étape 1, image 2 de 3 Rexing V1P Plus Screen Replacement, Front Camera: étape 1, image 3 de 3
    • Begin by orienting the device with the LCD screen facing down.
    • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
  2. Rexing V1P Plus Screen Replacement: étape 2, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 2, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 2, image 3 de 3
    • Remove the back cover of the device and place it to the side.
    • Rotate the device 180 degrees to where the camera is facing you.
  3. Rexing V1P Plus Screen Replacement: étape 3, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 3, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 3, image 3 de 3
    • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
  4. Rexing V1P Plus Screen Replacement: étape 4, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 4, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 4, image 3 de 3
    • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
  5. Rexing V1P Plus Screen Replacement: étape 5, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 5, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 5, image 3 de 3
    • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
  6. Rexing V1P Plus Screen Replacement: étape 6, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 6, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 6, image 3 de 3
    • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
    • It will rest loosely around the white camera ribbon.
    • Rotate the device 180 degrees to where the camera is facing away from you.
  7. Rexing V1P Plus Screen Replacement: étape 7, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 7, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 7, image 3 de 3
    • Carefully peel back the adhesive material covering the ribbon cable connection.
  8. Rexing V1P Plus Screen Replacement: étape 8, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 8, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 8, image 3 de 3
    • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
    • Once the connector is open, slide the ribbon cable out to remove it.
  9. Rexing V1P Plus Screen Replacement, Motherboard: étape 9, image 1 de 3 Rexing V1P Plus Screen Replacement, Motherboard: étape 9, image 2 de 3 Rexing V1P Plus Screen Replacement, Motherboard: étape 9, image 3 de 3
    • Using a soldering iron, disconnect the four wires connected to the motherboard.
  10. Rexing V1P Plus Screen Replacement: étape 10, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 10, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 10, image 3 de 3
    • Using the Phillips #00 screwdriver, remove the three 3.5 mm screws securing the motherboard to the case.
  11. Rexing V1P Plus Screen Replacement: étape 11, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 11, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 11, image 3 de 3
    • Pull the black antenna wire with the gold cap straight up to disconnect it from the motherboard.
    • Using your fingers, spread the case apart to provide space for the motherboard to be removed.
    • This must be done to free the connected ports from their mounting locations in the case.
  12. Rexing V1P Plus Screen Replacement, Screen: étape 12, image 1 de 2 Rexing V1P Plus Screen Replacement, Screen: étape 12, image 2 de 2
    • Once separated from the case, flip the motherboard over so the screen faces upward.
    • Rotate the motherboard so that the screen hangs over the top of the motherboard, as seen in the second image.
  13. Rexing V1P Plus Screen Replacement: étape 13, image 1 de 3 Rexing V1P Plus Screen Replacement: étape 13, image 2 de 3 Rexing V1P Plus Screen Replacement: étape 13, image 3 de 3
    • Using the Flathead 1.5mm screwdriver, flip up the black ZIF connector locking flap to free the ribbon cable.
    • Slide the ribbon cable out to remove it.
Tyler Anderson
Membre depuis le 02/14/23
94 Réputation
1 tutoriel rédigé
Équipe
1 commentaire de tutoriel
Where do I find the replacement screen?
Cesar Perez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 257
