Aller au contenu principal
Ricoh Theta S Outer Case Replacement
Ce dont vous avez besoin
  1. Ricoh Theta S Outer Case Replacement, Outer Case: étape 1, image 1 de 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: étape 2, image 1 de 2 Ricoh Theta S Outer Case Replacement: étape 2, image 2 de 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Outer Case Replacement: étape 3, image 1 de 3 Ricoh Theta S Outer Case Replacement: étape 3, image 2 de 3 Ricoh Theta S Outer Case Replacement: étape 3, image 3 de 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
Bradley Sutton
Membre depuis le 11/07/17
737 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S3-G1, Harley Fall 2017 Membre de l'équipe IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 membres
4 tutoriels rédigés
Un commentaire
Where can find spare part case?
Thanks
Franco - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 22
Total : 2,180
