Introduction
This process involves removing the back cover and the front cover of the camera. After, the lens can be removed from the camera body.
Outils
Pièces
Aucune pièce nécessaire.
Unscrew a total of seven screws from the left, right, bottom, and back sides of the camera.
The following step to remove the film compartment door is optional. However, it may aid in the maneuvering of the camera in future steps.
To remove the film compartment door, take a thin object such as a toothpick or a small screwdriver and push down on the metal pin holding the film compartment door in place.
After pushing the metal pin down, use your fingers to completely remove the metal pin.
After the metal pin has been removed, the film compartment door can be removed.
The lens is only attached to the main camera body. Set the front and back covers aside.
Unscrew three screws from the outermost plastic plate covering the lens.
After the screws are removed, the outermost plate can be removed.
