Aller au contenu principal
Ridgid Angle Grinder R10202 Disk Guard Spring Replacement
Ce dont vous avez besoin
  1. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement, Disk Guard Spring: étape 1, image 1 de 1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  2. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: étape 2, image 1 de 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: étape 2, image 2 de 2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  3. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: étape 3, image 1 de 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: étape 3, image 2 de 2
    • Unscrew the 5 M5 X 10mm screws using a Torx T20 Bit.
    • Carefully separate the spacer from the guard.
  4. Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: étape 4, image 1 de 2 Ridgid Angle Grinder R10202 Disk Guard Spring Replacement: étape 4, image 2 de 2
    • Gently push the spring away from the spacer.
    • The spacer, spring, and guard lever should now be all separate.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 729
