Introduction
If during a work session you accidentally drop the device and fracture the power trigger, you will need to replace it. The inner mechanism can also break resulting in a broken power trigger. This guide will show you how to disassemble the handle and replace the switch.
Ce dont vous avez besoin
Using a Torx T20 screwdriver, unscrew the five M5 x 16 mm screws.
Using the T20 screwdriver, remove the M5 x 28 mm screw.
Using a bit driver, carefully remove the 4 M3.5 X 7mm holding the wires on.
