Aller au contenu principal
Ridgid Angle Grinder R10202 Power Trigger Replacement
Ce dont vous avez besoin
  1. Ridgid Angle Grinder R10202 Power Trigger Replacement, Ridgid Angle Grinder R10202 Handle Disassembly: étape 1, image 1 de 3 Ridgid Angle Grinder R10202 Power Trigger Replacement, Ridgid Angle Grinder R10202 Handle Disassembly: étape 1, image 2 de 3 Ridgid Angle Grinder R10202 Power Trigger Replacement, Ridgid Angle Grinder R10202 Handle Disassembly: étape 1, image 3 de 3
    • Using a Torx T20 screwdriver, unscrew the five M5 x 16 mm screws.
    • Using the T20 screwdriver, remove the M5 x 28 mm screw.
  2. Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 2, image 1 de 1
    • Using a Torx T10 screwdriver, remove the M3 x 10mm screw.
  3. Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 3, image 1 de 2 Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 3, image 2 de 2
    • Gently pull off the right side handle.
  4. Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 4, image 1 de 3 Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 4, image 2 de 3 Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 4, image 3 de 3
    • Using a hex head screwdriver, remove the two 8-16 x 1/2in screws.
  5. Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 5, image 1 de 1
    • Gently pull away the bend relief.
  6. Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 6, image 1 de 2 Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 6, image 2 de 2
    • Remove the one M4 x 14 mm screw using a Phillips screwdriver.
  7. Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 7, image 1 de 1
    • Gently lift away the switch and wires.
  8. Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 8, image 1 de 2 Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 8, image 2 de 2
    • Press down the handle lock button.
    • Force-ably twist and pull away the left side handle assembly.
  9. Ridgid Angle Grinder R10202 Power Trigger Replacement, Power Trigger: étape 9, image 1 de 3 Ridgid Angle Grinder R10202 Power Trigger Replacement, Power Trigger: étape 9, image 2 de 3 Ridgid Angle Grinder R10202 Power Trigger Replacement, Power Trigger: étape 9, image 3 de 3
    • Using a bit driver, carefully remove the 4 M3.5 X 7mm holding the wires on.
    • Remember the order and position of each wire.
  10. Ridgid Angle Grinder R10202 Power Trigger Replacement: étape 10, image 1 de 1
    • The Switch is now free of the Grinder. Dispose of the broken Switch and install your new Switch.
Alexander Armstrong
Membre depuis le 01/10/19
85 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 442
