Aller au contenu principal
Ridgid Circular Saw R3205 Lower Blade Guard Replacement
Ce dont vous avez besoin
  1. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: étape 1, image 1 de 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: étape 1, image 2 de 2
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 2, image 1 de 1
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 3, image 1 de 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 3, image 2 de 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 3, image 3 de 3
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: étape 4, image 1 de 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: étape 4, image 2 de 2
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 5, image 1 de 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 5, image 2 de 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 5, image 3 de 3
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 6, image 1 de 1
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 7, image 1 de 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: étape 7, image 2 de 2
    • Remove the lower blade guard after removing the washer.
3 autres ont terminé cette réparation.
Joshua Caron
Membre depuis le 04/05/19
792 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G2, Julie Spring 2019 Membre de l'équipe UMass Dartmouth, Team S5-G2, Julie Spring 2019
UMASSD-JULIE-S19S5G2
5 membres
5 tutoriels rédigés
Un commentaire
Thank you so VERY much! I was stuck and this was perfectly described!
Chris Bishop - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 8
30 derniers jours : 28
Total : 1,988
