Introduction
The lower blade guard on a circular saw is to keep the user safe. The lower blade guard protects the blade from getting damaged and also protects the user from getting cut by the saw. If the lower blade guard is damaged (bent or broken) the guard should be replaced because you could be injured if the saw malfuctions. Replacing the lower blade guard is moderatly easy and doesn’t require any steps that are too complicated.
Ce dont vous avez besoin
Press the black spindle lock and hold it down.
While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
3 autres ont terminé cette réparation.
Un commentaire
Thank you so VERY much! I was stuck and this was perfectly described!
