Aller au contenu principal
Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement
Ce dont vous avez besoin
  1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: étape 1, image 1 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: étape 1, image 2 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: étape 1, image 3 de 3
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: étape 2, image 1 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: étape 2, image 2 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: étape 2, image 3 de 3
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: étape 3, image 1 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: étape 3, image 2 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: étape 3, image 3 de 3
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: étape 4, image 1 de 2 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: étape 4, image 2 de 2
    • The motor housing assembly can now be removed from the rest of the saw.
Joshua Caron
Membre depuis le 04/05/19
792 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G2, Julie Spring 2019 Membre de l'équipe UMass Dartmouth, Team S5-G2, Julie Spring 2019
UMASSD-JULIE-S19S5G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 12
Total : 366
