Aller au contenu principal
Ridgid Circular Saw R3205 Switch Replacement
Ce dont vous avez besoin
  1. Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: étape 1, image 1 de 3 Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: étape 1, image 2 de 3 Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: étape 1, image 3 de 3
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Switch Replacement: étape 2, image 1 de 3 Ridgid Circular Saw R3205 Switch Replacement: étape 2, image 2 de 3 Ridgid Circular Saw R3205 Switch Replacement: étape 2, image 3 de 3
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Switch Replacement: étape 3, image 1 de 3 Ridgid Circular Saw R3205 Switch Replacement: étape 3, image 2 de 3 Ridgid Circular Saw R3205 Switch Replacement: étape 3, image 3 de 3
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Switch Replacement: étape 4, image 1 de 2 Ridgid Circular Saw R3205 Switch Replacement: étape 4, image 2 de 2
    • The motor housing assembly can now be removed from the rest of the saw.
  5. Ridgid Circular Saw R3205 Switch Replacement, Switch: étape 5, image 1 de 1
    • Remove 5 Torx 20 (#8-16 x 5/8 in.) screws from the outer handle.
  6. Ridgid Circular Saw R3205 Switch Replacement: étape 6, image 1 de 3 Ridgid Circular Saw R3205 Switch Replacement: étape 6, image 2 de 3 Ridgid Circular Saw R3205 Switch Replacement: étape 6, image 3 de 3
    • Remove the outer handle.
  7. Ridgid Circular Saw R3205 Switch Replacement: étape 7, image 1 de 1
    • Using a phillips head screwdriver remove the (M4 x 12 mm) screw holding the switch in place.
  8. Ridgid Circular Saw R3205 Switch Replacement: étape 8, image 1 de 3 Ridgid Circular Saw R3205 Switch Replacement: étape 8, image 2 de 3 Ridgid Circular Saw R3205 Switch Replacement: étape 8, image 3 de 3
    • Remove the wires that attach to the power cord.
Joshua Caron
Membre depuis le 04/05/19
792 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G2, Julie Spring 2019 Membre de l'équipe UMass Dartmouth, Team S5-G2, Julie Spring 2019
UMASSD-JULIE-S19S5G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 18
Total : 745
