Introduction
If your Ridgid R175RNE nailer is firing sluggishly or not at all, then either the driver cylinder or driving blade O-rings may be worn out. Follow this guide to replace the driver cylinder O-rings.
The driver cylinder O-rings are what allows the cylinder to smoothly slide back and forth after the driving blade is fired.
Ce dont vous avez besoin
Use a 5/32" Allen wrench to remove the four 25 mm screws that secure the top cap.
Remove the top cap.
Remove the driver cylinder and place the nailer body to the side.
