Aller au contenu principal
Ridgid R4021 Blade Replacement
Ce dont vous avez besoin
  1. Ridgid R4021 Blade Replacement, Saw Blade: étape 1, image 1 de 3 Ridgid R4021 Blade Replacement, Saw Blade: étape 1, image 2 de 3 Ridgid R4021 Blade Replacement, Saw Blade: étape 1, image 3 de 3
    • Remove the top panel to access the saw blade.
    • Ensure any debris is cleared from the blade area.
  2. Ridgid R4021 Blade Replacement: étape 2, image 1 de 2 Ridgid R4021 Blade Replacement: étape 2, image 2 de 2
    • Remove the two included wrenches located on the right side of the unit.
  3. Ridgid R4021 Blade Replacement: étape 3, image 1 de 3 Ridgid R4021 Blade Replacement: étape 3, image 2 de 3 Ridgid R4021 Blade Replacement: étape 3, image 3 de 3
    • Fit the larger wrench around the nut on saw blade.
    • Fasten the smaller wrench to the screw coming through the blade.
    • Twist the bigger lever counter-clockwise while holding the smaller wrench in order to remove the nut.
  4. Ridgid R4021 Blade Replacement: étape 4, image 1 de 2 Ridgid R4021 Blade Replacement: étape 4, image 2 de 2
    • Remove the saw blade by tilting it away from the well wall.
    • Use caution when handling the saw blade.
  5. Ridgid R4021 Blade Replacement: étape 5, image 1 de 2 Ridgid R4021 Blade Replacement: étape 5, image 2 de 2
    • Place the new blade on the screw the same way the other blade was removed.
    • You can put the old blade in the new packaging to ensure safety.
Obelia Abarca
Membre depuis le 09/17/21
303 Réputation
2 tutoriels rédigés
Équipe
York University, Team C-1, O'Regan Fall 2021 Membre de l'équipe York University, Team C-1, O'Regan Fall 2021
YORK-O'REGAN-F21SCG1
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 44
Total : 2,191
