Introduction
If the Ridgid R4021 120V 7-inch Table Top Wet Tile Saw has begun to dull, then a replacement blade is needed. The blade will not be able cut through material properly if it is not sufficiently sharp and could result in slippage, the potential of user error by requiring too much force, and essentially might result in harm. By using this guide, the saw will be able to work properly, and cleaning the debris and maintaining the edge will help keep things running smoothly. Before beginning this guide, make sure to power off the device, remove the electric plug, and ensure area is clear for safety.
Ce dont vous avez besoin
