Introduction
The trigger is a multi-speed switch and requires replacing the whole assembly. Soldering is necessary for this guide. Please familiarize yourself with the iFixit guide on Soldering before starting.
Ce dont vous avez besoin
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Identify the LED light. The LED light is the component with clear casing and has two wires attached, located toward the bottom of the driver.
