Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide is to show how to open the Ring Doorbell to replace the battery. This is only for the 1st gen ring doorbells as newer versions do not have a battery and require full time power.
  1. Start by removing the 8 screws. the 4 black ones are hidden by the aluminum plate.
    • Start by removing the 8 screws. the 4 black ones are hidden by the aluminum plate.
  2. Pry the aluminum cover carefully off- this will reveal the 4 black screws underneath. You will need a micro phillips screwdriver to remove these tiny screws. Pry the aluminum cover carefully off- this will reveal the 4 black screws underneath. You will need a micro phillips screwdriver to remove these tiny screws.
    • Pry the aluminum cover carefully off- this will reveal the 4 black screws underneath. You will need a micro phillips screwdriver to remove these tiny screws.
  3. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  4. Carefully pry the plastic with a plastic pry tool to pop the insert out- watch the micro usb port that is sticking out...
    • Carefully pry the plastic with a plastic pry tool to pop the insert out- watch the micro usb port that is sticking out...
  5. carefully pull directly up  on the connector. The battery MAY still be attached to the plate-so be careful.
    • carefully pull directly up on the connector. The battery MAY still be attached to the plate-so be careful.
  6. This battery is two Lithium polymer batteries connected in parallel to the regulator. The batteries are back to back and are rated at  9.47wh @ 3.75v each...I have yet to find this battery but assume it is available somewhere in raw form.
    • This battery is two Lithium polymer batteries connected in parallel to the regulator. The batteries are back to back and are rated at 9.47wh @ 3.75v each...I have yet to find this battery but assume it is available somewhere in raw form.
    • assembly is pretty straight forward- just reassemble in reverse order- good luck!
12 autre(s) ont terminé cette réparation.
Greg Beeblebrox
Membre depuis le 11/06/2014
509 Réputation
1 tutoriel rédigé
32 commentaires
This is one of the few products that it's rarely if ever necessary to replace a battery in, as the warranty will cover a rapidly draining or not-charging battery. I'm glad you didn't tear down your chime, too! ;)
pyrodice - Réponse
Where can the battery be purchased?
Mike Menendez - Réponse
My ring doorbell is a little over a year old and battery is draining very fast so needs to be replaced. Ring says it is out of warranty and solution is to buy a new ring doorbell for $180. Not a good solution in my opinion. I just spent another $50 for the solar panel option (which is only compatible with the first generation ring doorbell) and this does not help so now I have $230 into this doorbell. If anyone knows where a replacement aftermarket battery can be purchased, I would appreciate this info.
bill hitchcock - Réponse
Please see my post below. I believe there is hope brother….
John Sanders -
At ham radio festivals there is a guy they call Mr. NICAD. He builds batteries for people. Just ask him.
wx9dx -
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 86
7 derniers jours : 484
30 derniers jours : 2,316
Total : 62,054
