Aller au contenu principal
Ring Stick Up Cam Battery Battery Replacement
  1. Ring Stick Up Cam Battery Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
  2. Ring Stick Up Cam Battery Battery Replacement: étape 2, image 1 de 1
    • Gently pull down to separate the stand from the camera body.
  3. Ring Stick Up Cam Battery Battery Replacement: étape 3, image 1 de 2 Ring Stick Up Cam Battery Battery Replacement: étape 3, image 2 de 2
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
Caroline Smith
Membre depuis le 02/24/23
267 Réputation
2 tutoriels rédigés
Équipe
Marist, Team 1-1, Chaterdon Spring 2023 Membre de l'équipe Marist, Team 1-1, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 45
Total : 515
