Introduction
If your Ring Stick Up Cam Battery (3rd Generation, model number 5UM7E5) is not powering on or operating correctly, there may be issues with the motherboard of your device.
Before using this guide, ensure that the battery for the device is fully charged and that the charging port is not damaged or faulty. If you are still experiencing issues with operating your device, your motherboard may need to be replaced. This guide will walk you through the necessary steps to locate and replace the motherboard of your device.
Ce dont vous avez besoin
Turn the camera so the lens is facing away from you, and the back is facing towards you.
Place one hand securely on the base and the other on the stand.
Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
Outil utilisé dans cette étape :Halberd Spudger$2.99
Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
Un commentaire
Would like to see a chip identification teardown in the future please 😊
