Aller au contenu principal
Ring Video Doorbell Camera Replacement
Ce dont vous avez besoin
  1. Ring Video Doorbell  Camera Replacement, Camera: étape 1, image 1 de 3 Ring Video Doorbell  Camera Replacement, Camera: étape 1, image 2 de 3 Ring Video Doorbell  Camera Replacement, Camera: étape 1, image 3 de 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminum plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell  Camera Replacement: étape 2, image 1 de 3 Ring Video Doorbell  Camera Replacement: étape 2, image 2 de 3 Ring Video Doorbell  Camera Replacement: étape 2, image 3 de 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell  Camera Replacement: étape 3, image 1 de 3 Ring Video Doorbell  Camera Replacement: étape 3, image 2 de 3 Ring Video Doorbell  Camera Replacement: étape 3, image 3 de 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell  Camera Replacement: étape 4, image 1 de 2 Ring Video Doorbell  Camera Replacement: étape 4, image 2 de 2
    • Using the Plating Tool Opener, arefully disconnect the ribbon cable that attaches the camera to the housing.
    • Replace camera, and follow the steps in reverse order to reassemble
    Where do you find the replacement camera dropped mine and cameras lens busted?
    Michelle McCord - Réponse
    Ok now now that you told me how to replace the camera. Where can I buy a camera to replace my scratched and broken lens?
    Help!??
    Evrt M - Réponse
    Same here, where do you get the replacement from?
    Steve.D70 - Réponse
  5. Ring Video Doorbell  Camera Replacement: étape 5, image 1 de 2 Ring Video Doorbell  Camera Replacement: étape 5, image 2 de 2
    • Unscrew the two 1 mm screws using the PH00 Philips Screwdriver.
    • Detach the black and red wire connected to the motherboard, using the tweezers, to remove the camera.
3 autres ont terminé cette réparation.
Isaiah Wilson
Membre depuis le 02/20/18
231 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 membres
10 tutoriels rédigés
8 commentaires
What camera should I use to replace a malfunctioning camera in the ring video doorbell? And where do I buy it?
jonathan.byus - Réponse
Bump. What camera should I use to replace? (Scratched Lens.) Is the lens you can touch, a lens, or is it just a cover? Mine fell at there is chip right in the center that make the image unusable.
Bobby Diggins - Réponse
I have a scratch dead center of mine too. Have no clue how it got there as I’m super careful when I take it off to charge. Ugh. did you find out where to buy a replacement?
Kim Townsend -
What camera should I use to replace? (Scratched Lens.)  I have the right 1st generation with a 740p camera
meanltltoo - Réponse
Has anyone found a replacement camera online?
christina.stewart - Réponse
So what's up with trying to find a replacement camera cuz my lens is broken?
Evrt M - Réponse
I also need to know where to buy the replacement lens?? I’m not seeing that question answered by anyone….
Dawn Smith - Réponse
Same here, pointless showing how to replace it if we don’t know where to get a replacement other than a used item.
Steve.D70 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 37
30 derniers jours : 153
Total : 15,577
