Aller au contenu principal
Ring Video Doorbell Speakers Replacement
Ce dont vous avez besoin
  1. Ring Video Doorbell  Speakers Replacement, Motherboard: étape 1, image 1 de 3 Ring Video Doorbell  Speakers Replacement, Motherboard: étape 1, image 2 de 3 Ring Video Doorbell  Speakers Replacement, Motherboard: étape 1, image 3 de 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell  Speakers Replacement: étape 2, image 1 de 3 Ring Video Doorbell  Speakers Replacement: étape 2, image 2 de 3 Ring Video Doorbell  Speakers Replacement: étape 2, image 3 de 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell  Speakers Replacement: étape 3, image 1 de 3 Ring Video Doorbell  Speakers Replacement: étape 3, image 2 de 3 Ring Video Doorbell  Speakers Replacement: étape 3, image 3 de 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell  Speakers Replacement: étape 4, image 1 de 2 Ring Video Doorbell  Speakers Replacement: étape 4, image 2 de 2
    • Detach the upper part of the motherboard from the bottom, using your hands.
  5. Ring Video Doorbell  Speakers Replacement, Speakers: étape 5, image 1 de 1
    • Speakers are two small rectangles located above the button of the doorbell.
  6. Ring Video Doorbell  Speakers Replacement: étape 6, image 1 de 1
    • To remove the speakers pry each one out carefully with a plastic opening tool.
Oscar Pascual-Diego
Membre depuis le 02/20/18
112 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 membres
10 tutoriels rédigés
Un commentaire
Where does one get replacement speakers for the 88RG000FC100 ring doorbell?
Jeffrey Lang - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 27
30 derniers jours : 102
Total : 4,164
