Aller au contenu principal
Ring Video Doorbell Housing Replacement
Ce dont vous avez besoin
  1. Ring Video Doorbell Housing Replacement, Housing: étape 1, image 1 de 3 Ring Video Doorbell Housing Replacement, Housing: étape 1, image 2 de 3 Ring Video Doorbell Housing Replacement, Housing: étape 1, image 3 de 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Housing Replacement: étape 2, image 1 de 3 Ring Video Doorbell Housing Replacement: étape 2, image 2 de 3 Ring Video Doorbell Housing Replacement: étape 2, image 3 de 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell Housing Replacement: étape 3, image 1 de 3 Ring Video Doorbell Housing Replacement: étape 3, image 2 de 3 Ring Video Doorbell Housing Replacement: étape 3, image 3 de 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell Housing Replacement: étape 4, image 1 de 1
    • Remove the plastic film using the Plastic Tool Opener.
3 autres ont terminé cette réparation.
Abdulrahman
Membre depuis le 02/20/18
685 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 membres
10 tutoriels rédigés
Un commentaire
Hey, do you know if Ring will provide you with replacement front housing? My casing has been damaged by an attempted theft :(
Charlie Adamson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 34
Total : 3,168
