Aller au contenu principal
Rival CM4015 Water Tubes Replacement
Ce dont vous avez besoin
  1. Rival CM4015 Water Tubes Replacement, Base Plate: étape 1, image 1 de 2 Rival CM4015 Water Tubes Replacement, Base Plate: étape 1, image 2 de 2
    • Remove the three 16 mm tri-point screws from the base plate.
  2. Rival CM4015 Water Tubes Replacement: étape 2, image 1 de 2 Rival CM4015 Water Tubes Replacement: étape 2, image 2 de 2
    • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
  3. Rival CM4015 Water Tubes Replacement, Power Button: étape 3, image 1 de 1
    • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
  4. Rival CM4015 Water Tubes Replacement: étape 4, image 1 de 2 Rival CM4015 Water Tubes Replacement: étape 4, image 2 de 2
    • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
    • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
  5. Rival CM4015 Water Tubes Replacement: étape 5, image 1 de 2 Rival CM4015 Water Tubes Replacement: étape 5, image 2 de 2
    • Clean both the button and its slot before replacing the power button.
  6. Rival CM4015 Water Tubes Replacement, Heating Element: étape 6, image 1 de 1
    • Remove the two 8 mm Phillips screws from the plastic body.
  7. Rival CM4015 Water Tubes Replacement: étape 7, image 1 de 2 Rival CM4015 Water Tubes Replacement: étape 7, image 2 de 2
    • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
    • Pull back the metal backing from the plastic body.
  8. Rival CM4015 Water Tubes Replacement: étape 8, image 1 de 3 Rival CM4015 Water Tubes Replacement: étape 8, image 2 de 3 Rival CM4015 Water Tubes Replacement: étape 8, image 3 de 3
    • Remove the four 8 mm Phillips screws from the inner plastic body.
    • You will need a long, thin Phillips screw driver to get this deep into the device.
  9. Rival CM4015 Water Tubes Replacement: étape 9, image 1 de 2 Rival CM4015 Water Tubes Replacement: étape 9, image 2 de 2
    • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
    • Take your time to make sure the thin cables within the device don't tear.
  10. Rival CM4015 Water Tubes Replacement: étape 10, image 1 de 1
    • Remove the two 8 mm Phillips screws from the metal backing.
  11. Rival CM4015 Water Tubes Replacement: étape 11, image 1 de 1
    • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
    • You may also use pliers for this step if the springs are too strong.
  12. Rival CM4015 Water Tubes Replacement: étape 12, image 1 de 1
    • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
  13. Rival CM4015 Water Tubes Replacement, Water Tubes: étape 13, image 1 de 1
    • Remove the two rubber water tubes from the heating element by firmly pulling each at a 90 degree angle from the socket.
Michael Murdock
Membre depuis le 10/06/16
279 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-6, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 10-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G6
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 249
