Aller au contenu principal
Rival Crock Pot 3120 Disassembly
Ce dont vous avez besoin
Document vedette
  1. Rival Crock Pot 3120 Disassembly, Rival Crock Pot 3120 Disassembly: étape 1, image 1 de 1
    • Remove the lid from the crockpot and turn the device over, so that the bottom faces up.
  2. Rival Crock Pot 3120 Disassembly: étape 2, image 1 de 2 Rival Crock Pot 3120 Disassembly: étape 2, image 2 de 2
    • Use your fingers to remove the rubber end cap from the bolt on the bottom of the device.
  3. Rival Crock Pot 3120 Disassembly: étape 3, image 1 de 2 Rival Crock Pot 3120 Disassembly: étape 3, image 2 de 2
    • Using a 10mm wrench, remove the metal nut on the bottom of the device.
    • If the bolt connected to the nut appeared to fall into the device this is not an issue. It is connected to a metal bar within the device, so it cannot be lost.
  4. Rival Crock Pot 3120 Disassembly: étape 4, image 1 de 2 Rival Crock Pot 3120 Disassembly: étape 4, image 2 de 2
    • Using your hands, pull the plastic dial off the side of the device.
  5. Rival Crock Pot 3120 Disassembly: étape 5, image 1 de 3 Rival Crock Pot 3120 Disassembly: étape 5, image 2 de 3 Rival Crock Pot 3120 Disassembly: étape 5, image 3 de 3
    • Remove the nut behind the dial using a 16mm wrench.
    • Once the nut has been loosened you can finish unscrewing it with your hand.
  6. Rival Crock Pot 3120 Disassembly: étape 6, image 1 de 3 Rival Crock Pot 3120 Disassembly: étape 6, image 2 de 3 Rival Crock Pot 3120 Disassembly: étape 6, image 3 de 3
    • Remove the bottom panel using your hands.
  7. Rival Crock Pot 3120 Disassembly: étape 7, image 1 de 3 Rival Crock Pot 3120 Disassembly: étape 7, image 2 de 3 Rival Crock Pot 3120 Disassembly: étape 7, image 3 de 3
    • Slide the power cord out of its slot in the metal casing.
  8. Rival Crock Pot 3120 Disassembly: étape 8, image 1 de 2 Rival Crock Pot 3120 Disassembly: étape 8, image 2 de 2
    • Pull the rotary switch out from inside the metal casing.
  9. Rival Crock Pot 3120 Disassembly: étape 9, image 1 de 3 Rival Crock Pot 3120 Disassembly: étape 9, image 2 de 3 Rival Crock Pot 3120 Disassembly: étape 9, image 3 de 3
    • Slide the metal casing up and away from the internal components of the device.
  10. Rival Crock Pot 3120 Disassembly: étape 10, image 1 de 3 Rival Crock Pot 3120 Disassembly: étape 10, image 2 de 3 Rival Crock Pot 3120 Disassembly: étape 10, image 3 de 3
    • You have now successfully disassembled your device. From here you can troubleshoot or replace any specific parts.
Pièces jointes
Cole J. Morrel
Membre depuis le 09/14/22
181 Réputation
1 tutoriel rédigé
4 commentaires
Reassembly is difficult, the bolt on the bottom is too short!
Johnb - Réponse
Bolt is way too short to reassemble this thing and I'm not strong enough to bend the wire bail no matter how I try to do it. Never should have taken the thing apart.
Bob Hodge - Réponse
It has been quite a long time since I went through this process but I seem to remember wrapping the threaded part of the bot in dental floss to use as a guide and threaded it through the hole with the crockpot propped up, upright so gravity would aid in assembly (some tire chocks on their sides would work, I think). It took some patience or perhaps stubbornness? But that's how I got it reassembled. I had a really hard time getting the bolt centered and the wire bail part vertical, which made the bolt seem impossibly short, before I tried this approach.
D. Marie Olsen Zito -
The bolt is definitely too short. I was taking it apart to clean it up- had I known, I wouldn't have bothered. I did bend the wire and tied some thread to the bolt- I was determined to not let it get the best of me.
Those heating wires that wrap around the pot are so thin, I was worried about breaking one. When I got it out back together I put some water in it and turn it on low- it was still working.
John Kershisnik - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 60
Total : 1,135
