Aller au contenu principal
Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement
Ce dont vous avez besoin
  1. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, How to Open the Rocketfish RF-WHTIB-A Sender: étape 1, image 1 de 1
    • Remove the four rubber tabs from the bottom of the sender.
    • Pull hard to peel off the rubber tabs, as they are attached with adhesive.
  2. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the four 12 mm screws on the bottom of the device.
  3. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 3, image 1 de 2 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 3, image 2 de 2
    • Flip the device over and remove the top casing from the sender.
  4. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Wireless Audio Module Chip: étape 4, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
  5. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 5, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the motherboard.
  6. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 6, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the two 10 mm screws located on either side of the speakers.
    • Secure the front speaker input terminal to release the motherboard.
  7. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 7, image 1 de 2 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 7, image 2 de 2
    • Using both thumbs, push the front speaker input terminal back towards the inside part of the device.
  8. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 8, image 1 de 1
    • Flip over the motherboard and wireless audio module chip.
  9. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Gently slide the black retaining flap back, securing the ribbon wire gently away from the white bar.
    • There should only be a small separation between the white bar and the black retaining flap.
    • Tweezers are recommended for this step.
  10. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: étape 10, image 1 de 1
    • Using your fingers, pull the ribbon wire out from the black retaining flap in order to completely disconnect the wireless audio module chip.
  11. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: étape 11, image 1 de 2 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: étape 11, image 2 de 2
    • Desolder the four metallic clasps that attach the panel to the motherboard.
    • For soldering techniques, follow the step in iFixit's soldering guide.
    • Do not attempt to solder if you are inexperienced.
To attach a new speaker input terminal, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Caitlin Charlton
Membre depuis le 03/22/15
756 Réputation
6 tutoriels rédigés
Équipe
Baylor, Team 4-2, Williams Spring 2015 Membre de l'équipe Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 membres
6 tutoriels rédigés
Un commentaire
Where can I get a replacement input terminal?
Greg Surrett (terminal case) - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 16
Total : 2,267
