Aller au contenu principal
Roku 2 Roku 2 Motherboard Replacement
Ce dont vous avez besoin
  1. Roku 2 Roku 2 Motherboard Replacement, Roku 2 Motherboard: étape 1, image 1 de 1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
  2. Roku 2 Roku 2 Motherboard Replacement: étape 2, image 1 de 1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2 Roku 2 Motherboard Replacement: étape 3, image 1 de 1
    • Remove the four Phillips #000 screws from the bottom of the case.
  4. Roku 2 Roku 2 Motherboard Replacement: étape 4, image 1 de 1
    • Gently remove the under side of the device.
  5. Roku 2 Roku 2 Motherboard Replacement: étape 5, image 1 de 1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2 Roku 2 Motherboard Replacement: étape 6, image 1 de 1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2 Roku 2 Motherboard Replacement: étape 7, image 1 de 1
    • Remove the board from the plastic enclosure.
Eric Rawls
Membre depuis le 08/24/15
360 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Sullivan Fall 2015 Membre de l'équipe USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 1,160
