Aller au contenu principal
Roku 3 A/C Power Port Replacement
Ce dont vous avez besoin
  1. Roku 3 A/C Power Port Replacement, Motherboard: étape 1, image 1 de 1
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 A/C Power Port Replacement: étape 2, image 1 de 3 Roku 3 A/C Power Port Replacement: étape 2, image 2 de 3 Roku 3 A/C Power Port Replacement: étape 2, image 3 de 3
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 A/C Power Port Replacement: étape 3, image 1 de 1
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 A/C Power Port Replacement: étape 4, image 1 de 2 Roku 3 A/C Power Port Replacement: étape 4, image 2 de 2
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 A/C Power Port Replacement: étape 5, image 1 de 1
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 A/C Power Port Replacement: étape 6, image 1 de 2 Roku 3 A/C Power Port Replacement: étape 6, image 2 de 2
    • Pull away the IO shield from the motherboard using your hands.
  7. Roku 3 A/C Power Port Replacement, A/C Power Port: étape 7, image 1 de 2 Roku 3 A/C Power Port Replacement, A/C Power Port: étape 7, image 2 de 2
    • Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
    • Orient it such that the backside of the HDMI port is in your upper right corner.
  8. Roku 3 A/C Power Port Replacement: étape 8, image 1 de 1
    • Desolder the connections of the A/C Power Port on the motherboard.
    • Remove the port.
    • For more information on soldering, check out iFixit's Soldering Guide.
Andy Hak
Membre depuis le 10/07/16
250 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-2, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 membres
6 tutoriels rédigés
Un commentaire
What’s the size and name of the actual jack? Where do I get a replacement one?
Bo Northwest Designs of SE - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 2,480
