Aller au contenu principal
Roku 3 Remote Control Motherboard Replacement
Ce dont vous avez besoin
  1. Roku 3 Remote Control Motherboard Replacement, Remote Control Battery: étape 1, image 1 de 1
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
  2. Roku 3 Remote Control Motherboard Replacement: étape 2, image 1 de 2 Roku 3 Remote Control Motherboard Replacement: étape 2, image 2 de 2
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
  3. Roku 3 Remote Control Motherboard Replacement: étape 3, image 1 de 1
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
  4. Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: étape 4, image 1 de 2 Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: étape 4, image 2 de 2
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
  5. Roku 3 Remote Control Motherboard Replacement: étape 5, image 1 de 2 Roku 3 Remote Control Motherboard Replacement: étape 5, image 2 de 2
    • Gently pry open the remote using the plastic opening tool.
  6. Roku 3 Remote Control Motherboard Replacement: étape 6, image 1 de 2 Roku 3 Remote Control Motherboard Replacement: étape 6, image 2 de 2
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
  7. Roku 3 Remote Control Motherboard Replacement: étape 7, image 1 de 1
    • Set aside the half of the remote with the buttons.
    • Take the the other half of the remote with one hand and remove the motherboard with your thumb and forefinger of the other hand.
3 autres ont terminé cette réparation.
Isobelle Espiritu
Membre depuis le 10/06/16
591 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 15-2, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 membres
6 tutoriels rédigés
4 commentaires
Thanks for the tutorial. Any idea where I can buy the motherboard for the Roku 3 remote?
Bret Dennis - Réponse
Where can I buy a Roku 3 remote motherboard replacement?
A. J. Sitarsky - Réponse
Hi, wondered if you had any luck locating a motherboard for the Roku 3? Thanks!
Paul Cacioppo -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 19
Total : 5,043
