Aller au contenu principal
Roku Streaming Stick Motherboard Port replacement
Ce dont vous avez besoin
  1. Roku Streaming Stick Motherboard Port replacement, Roku Streaming Stick Motherboard Port: étape 1, image 1 de 1
    • Grab the blue plastic opening tool to open the Roku Streaming Stick 3500R.
  2. Roku Streaming Stick Motherboard Port replacement: étape 2, image 1 de 2 Roku Streaming Stick Motherboard Port replacement: étape 2, image 2 de 2
    • Place the blue plastic opening tool into one of the cracks on the back of the Roku to pop open the Roku Streaming Stick 3500R. Be careful not to break anything while removing the back.
  3. Roku Streaming Stick Motherboard Port replacement: étape 3, image 1 de 1
    • Once you have removed the cover, you can now access the motherboard of the Roku Streaming Stick.
  4. Roku Streaming Stick Motherboard Port replacement: étape 4, image 1 de 2 Roku Streaming Stick Motherboard Port replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the motherboard by grabbing a hold of the micro-usb port, or you can also use tweezers to grab a hold of it and pull it out. But be careful with where you grab the motherboard.
  5. Roku Streaming Stick Motherboard Port replacement: étape 5, image 1 de 3 Roku Streaming Stick Motherboard Port replacement: étape 5, image 2 de 3 Roku Streaming Stick Motherboard Port replacement: étape 5, image 3 de 3
    • Once you identify the HDMI port and the micro-usb port, you can investigate to see which port may be damaged.
  6. Roku Streaming Stick Motherboard Port replacement: étape 6, image 1 de 2 Roku Streaming Stick Motherboard Port replacement: étape 6, image 2 de 2
    • Once you have identified the problem you can then desolder the points at the HDMI as highlighted, or at the micro-usb ports.
    • If the soldering gun, or iron is set too high you then run the risk of destroying the motherboard altogether, or even damaging the wireless antennas.
If the replacement of the motherboard does not work, another part may need to be replaced.
For reassembly, follow instructions in reverse order.
4 autres ont terminé cette réparation.
Andy Miller
Membre depuis le 04/07/18
203 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G2, Wilson Spring 2018 Membre de l'équipe IUPUI, Team S2-G2, Wilson Spring 2018
IUPUI-WILSON-S18S2G2
4 membres
3 tutoriels rédigés
Un commentaire
Any idea where to buy a new hdmi port to solder on?
exxonchavez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 22
Total : 3,851
