Aller au contenu principal
Roku XD 2050X Motherboard Replacement
Ce dont vous avez besoin
  1. Roku XD 2050X Motherboard Replacement, Case: étape 1, image 1 de 3 Roku XD 2050X Motherboard Replacement, Case: étape 1, image 2 de 3 Roku XD 2050X Motherboard Replacement, Case: étape 1, image 3 de 3
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Roku XD 2050X Motherboard Replacement: étape 2, image 1 de 2 Roku XD 2050X Motherboard Replacement: étape 2, image 2 de 2
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Roku XD 2050X Motherboard Replacement: étape 3, image 1 de 3 Roku XD 2050X Motherboard Replacement: étape 3, image 2 de 3 Roku XD 2050X Motherboard Replacement: étape 3, image 3 de 3
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  4. Roku XD 2050X Motherboard Replacement: étape 4, image 1 de 2 Roku XD 2050X Motherboard Replacement: étape 4, image 2 de 2
    • Remove the two Phillips #1 8mm pan-head screws.
  5. Roku XD 2050X Motherboard Replacement: étape 5, image 1 de 1
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  6. Roku XD 2050X Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Replace the faulty motherboard with the new motherboard.
    • Be sure to dispose of the faulty motherboard properly. Recycle if possible!
William
Membre depuis le 01/30/15
1 603 Réputation
10 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 4,963
