Aller au contenu principal
Roku XD 2050X Remote IR LED Replacement
Ce dont vous avez besoin
  1. Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: étape 1, image 1 de 2 Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: étape 1, image 2 de 2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote IR LED Replacement: étape 2, image 1 de 2 Roku XD 2050X Remote IR LED Replacement: étape 2, image 2 de 2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote IR LED Replacement: étape 3, image 1 de 1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote IR LED Replacement: étape 4, image 1 de 1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote IR LED Replacement: étape 5, image 1 de 1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote IR LED Replacement, Remote IR LED: étape 6, image 1 de 1
    • Desolder the two contacts for the IR LED.
    • Remove the IR LED from the circuit board.
    • For help with soldering view the ifixit soldering guide.
William
Membre depuis le 01/30/15
1 603 Réputation
10 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 10
Total : 907
