Aller au contenu principal
Roomba Pro Elite Drive Wheel Belts Replacement
Ce dont vous avez besoin
  1. Roomba Pro Elite Drive Wheel Belts Replacement, Drive Wheel Belt: étape 1, image 1 de 2 Roomba Pro Elite Drive Wheel Belts Replacement, Drive Wheel Belt: étape 1, image 2 de 2
    • Go ahead and remove the dust bin.
    • Then flip the roomba over and remove the battery.
  2. Roomba Pro Elite Drive Wheel Belts Replacement: étape 2, image 1 de 3 Roomba Pro Elite Drive Wheel Belts Replacement: étape 2, image 2 de 3 Roomba Pro Elite Drive Wheel Belts Replacement: étape 2, image 3 de 3
    • The upper housing is held in place by eight phillips #2 screws on the underside of the machine. Removing the four screws around the battery compartment is the most difficult step in servicing the robot.
    • The recess holes around the battery compartment, are 5.85 mm in diameter. The thinest old school #2 phillips I could find, has a shank diameter of 5.90 mm. Humm, did they do this on purpose to make working on these difficult?
    • Well, the easiest way I found to overcome this problem was to ream out the holes to 1/4 inch. I used the wrench from a tap and die set, an ordinary drill, and a drill collar; to carefully ream out the holes by hand.
    • If you don't have all that, you can use a regular drill. Be careful though not to hit the screw as the drill bit with strip it and make it very hard to remove. The factory sets these screws very tight and they are difficult to take out if they have not been removed before.
  3. Roomba Pro Elite Drive Wheel Belts Replacement: étape 3, image 1 de 1
    • Now go ahead and remove all eight screws. (please excuse the battery in the picture, you should have removed it back in step 1.)
  4. Roomba Pro Elite Drive Wheel Belts Replacement: étape 4, image 1 de 1
    • If you made it this far, the worst is past. Carefully maneuver the top housing until it comes free.
    • The control panel in the top is connected by a ribbon cable, detach it at the circuit board.
3 autres ont terminé cette réparation.
SamGeorge
Membre depuis le 01/11/13
173 Réputation
1 tutoriel rédigé
5 commentaires
Thank you! You speed up my repair time to half
Michael Fiala - Réponse
Great!
Now where can I aquire a new belt?
That is my biggest problem
Jef Hern - Réponse
I also need a new belt, but can’t fine one either. Jef Hern, did you ever find one?
magicmickeydonna - Réponse
You can get the same belt from the roomba 4000
LakeM0nst3r -
If you can’t find the belt the roomba 4000 uses the same belt or the discovery series
LakeM0nst3r -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 17
Total : 2,560
