Aller au contenu principal
Rosewill NEON M62 Sensor Cover Replacement
Ce dont vous avez besoin
  1. Rosewill NEON M62 Sensor Cover Replacement, Bottom Panel: étape 1, image 1 de 1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Sensor Cover Replacement: étape 2, image 1 de 1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Sensor Cover Replacement: étape 3, image 1 de 2 Rosewill NEON M62 Sensor Cover Replacement: étape 3, image 2 de 2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Sensor Cover Replacement, Sensor Cover: étape 4, image 1 de 1
    • Remove the four 5 mm screws with a Philips #00 screwdriver.
  5. Rosewill NEON M62 Sensor Cover Replacement: étape 5, image 1 de 2 Rosewill NEON M62 Sensor Cover Replacement: étape 5, image 2 de 2
    • Remove the center clear plastic piece, known as the sensor cover.
Sean Turk
Membre depuis le 03/16/23
217 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 Membre de l'équipe UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G2
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 62
