Aller au contenu principal
Rotary Multi Selector Wheel Removal
Ce dont vous avez besoin
  1. Rotary Multi Selector Wheel Removal, Back Cover Removal: étape 1, image 1 de 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: étape 1, image 2 de 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: étape 1, image 3 de 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  2. Rotary Multi Selector Wheel Removal: étape 2, image 1 de 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  3. Rotary Multi Selector Wheel Removal, Detaching Ribbon: étape 3, image 1 de 2 Rotary Multi Selector Wheel Removal, Detaching Ribbon: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  4. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: étape 4, image 1 de 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: étape 4, image 2 de 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: étape 4, image 3 de 3
    J'achète
    • Lift up the metal cover and its button slowly using the tweezers.
Andrew Lau
Membre depuis le 04/18/13
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 8-56, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 533
