Aller au contenu principal
Royal Heat RS-100 Fuse Replacement
Ce dont vous avez besoin
  1. Royal Heat RS-100 Fuse Replacement, Panel: étape 1, image 1 de 1
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Royal Heat RS-100 Fuse Replacement: étape 2, image 1 de 3 Royal Heat RS-100 Fuse Replacement: étape 2, image 2 de 3 Royal Heat RS-100 Fuse Replacement: étape 2, image 3 de 3
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Royal Heat RS-100 Fuse Replacement: étape 3, image 1 de 1
    • Remove the two dial caps from the two switches by lifting them up.
  4. Royal Heat RS-100 Fuse Replacement, Fuse: étape 4, image 1 de 2 Royal Heat RS-100 Fuse Replacement, Fuse: étape 4, image 2 de 2
    • Do not pry from the middle of the fuse because some fuses are made of glass.
    • Pry one end of the fuse from the bracket until it is separated from the holder.
    • Remove the fuse by lifting it up.
Long Tran
Membre depuis le 10/14/13
205 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-35, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 11-35, Amido Fall 2013
CPSU-AMIDO-F13S11G35
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 12
Total : 598
